mallwood
Message 1 of 4
IPv6 config on D-link routers (DIR-878)
Hi,
Has anyone had any luck getting IPv6 working on a D-link router with a separate Openreach modem?
It has IPv6 connection options of Auto Detect, Static IPv6, Auto Config (SLAAC/DHCPv6), PPPoE, IPv6 in IPv4 tunnel, 6to4, 6rd and Local connectivity only
I've tried Auto Detect, Auto Config (SLAAC/DHCPv6) and PPPoE as looking most likely, but it never seems to connect.
Each of the options have other configurations as well, which makes life more complicated. SLAAC/DHCPv6 for instance has
Enable DHCP-PD, Enable Automatic IPv6 assignment, Enable Automatic DHCP-PD in LAN and Autoconfiguration type (SLAAC+RDNSS, SLAAC + stateless DHCP and stateful DHCPv6) for example
3 REPLIES 3
TimCurtis
Guru
Message 2 of 4
Re: IPv6 config on D-link routers (DIR-878)
All I can say is that on my Asus the settings are:-
Connection Type: Native
Interface: PPP
DHCP-PD : Enable
Auto Config Setting: Stateless
Connect to DNS Server automatically: Enable
Enable Router Advertisement: Enable
That may or may not help, but note that I think not all IPV6  routers are compatible with BT's implementation of it.
mallwood
Message 3 of 4
Yeah, trying to get as close to that as possible didn't work I'm afraid. Also trying to go through D-link support, but thought there may be someone that had got it working here.
If all else fails I may try dd-wrt, as that should have all the settings needed
licquorice
Message 4 of 4
Its possible that the D-Link doesn't support /56PD, not all routers do.
