JB0999
Newbie
Message 1 of 5
IPv6 disable? on Smart Hub
Hi all,
how can i disable IPv6 on my smart hub?
I want to use a Fingbox to restict access to the internet.
TIA
JB
4 REPLIES 4
Message 2 of 5
Re: IPv6 disable? on Smart Hub
You can't.
JB0999
Newbie
Message 3 of 5
new router it is then 😕
Message 4 of 5
Good plan.
V_Meldrew
Recognised Expert
Message 5 of 5
@JB0999wrote:
Hi all,
TIA
JB
Have you looked at Advanced Settings / BT Access Control?
It allows you to restrict access to the internet from any device on your network at times that you specify
