PG-Username
Newbie
Message 1 of 7
IPv6
Hello everyone,
I've got a new line and broadband from BT, before I placed order I was told that IPv6 is provided automatically with every new broadband.
After line installation I couldn't get IPv6 address so had to call number of times help desk / support team as well as "BT Tech Expert team" , but some do not even know what IPv6 is, and the experts can't check if I am provided with IPv6 address/service or not. BT should have two emails from me with question regarding this problem, but so far no answer.
Any idea where I could check it or who I can contact?
6 REPLIES 6
Message 2 of 7
Re: IPv6
IPv6 is currently not available on BT Residential service
Message 3 of 7
Re: IPv6
See these links for test and also BT blurb on it
http://test-ipv6.com/
http://ipv6.bt.com/Default.aspx
PG-Username
Newbie
Message 4 of 7
Re: IPv6
I see..
so BT provided wrong/misleading information regarding services which they provide? Surprisingly at the help desk as well as the BT Tech Expert Team told me that it should work and if there is an issue it would be probably with my router...
So they simply don't know???
Thank you
PG-Username
Newbie
Message 5 of 7
Re: IPv6
Thank you, I know I don't have IPv6, I do not need to test that 😕
Distinguished Guru
Message 6 of 7
Re: IPv6
I think the sentence "In BT, we are preparing for the transition to IPv6." (from http://ipv6.bt.com/Default.aspx) pretty much sums up BT's current position.
They are still planning IPv6 support.
They are now running so short of IPv4 addresses that they are quietly switching some customers to Carrier Grade NAT. http://btsupport.custhelp.com/app/answers/detail/a_id/44044/c/6433
Jonkarra
Expert
Message 7 of 7
Re: IPv6
TBH carrier grade NAT isn't an issue for most average users. It would be nice to start seeing the world make the switch however.
