Message 11 of 13
Re: ITV hub not playing properly
Thanks for the response.
I have reset the hub and no change, even when I place the machine adjacent to the router. I have used an ethernet cable and first the picture had a series of blue and white dots moving left to right then it became pixelated.
This seems to indicate a hardware problem to me but I have no idea what. If it is a low signal could you please advise the options?
I really do appreciate you patience in the matter. Thanks
Message 12 of 13
If you have tried a direct Ethernet cable to the computer, then its sound like a hardware problem with the computer. I assume you have also tried the Google Chrome web browser?
Apart from that, I have no other suggestions, as the site is simply a web page with video, just like the BBC iplayer.
Does the BBC iPlayer site work?
https://www.bbc.co.uk/iplayer
Message 13 of 13
Thanks for this.
I concur, as I can see no other explanation.  Subject to the following, I will contact an IT expert to attempt to ascertain what sort of hardware there may be.  Now answering your questions:
I tried Chrome and IE and they both have the same issue.
BBC iPlayer functions but comes up with a message 'not sufficient bandwidth' and then buffers.  I find this strange as BBC iPlayer plays perfectly well on both my old computer and the Panasonic Smart TV I have:  I would have thought if bandwidth was the issue it would show up as a problem on all devices.
Is there a way to check bandwidth or to extend it?
Once again thanks for all your help.
