Message 1 of 3
In the devices on my Bt Hub 'ThingsTurn_9CD1' has suddenly appeared no idea what it is anyone else h
In the devices on my Bt Hub 'ThingsTurn_9CD1' has suddenly appeared no idea what it is anyone else help?
2 REPLIES 2
Message 2 of 3
Re: In the devices on my Bt Hub 'ThingsTurn_9CD1' has suddenly appeared no idea what it is anyone el
If you put its MAC address in the lookup here  it will tell you the manufacturer of the device which might give you a clue to what it is.
Message 3 of 3
Many thanks I will try that shortly!!
