amcenteggart
Message 1 of 6
Indoor wireless camera - Wi Fi Connection Problem Home Hub 6
Hi I have an indoor wireless camera that I had set up with my home hub 5, now I've upgraded to the home hub 6 I can't get a Wi Fi connection.
I get a message during set up that the camera does not support 5g during set up so I turned smart set up to off, split the bands with "on" and turned 5g off in advanced setting but I'm still not getting anywhere.
I'd appreciate any help please.
Thanks,
Al.
5 REPLIES 5
lnajr02
Recognised Expert
Message 2 of 6
Re: Indoor wireless camera - Wi Fi Connection Problem Home Hub 6
Hi
What is the make of the Camera please?  If it’s only 2.4Ghz Wi-Fi and older tech it may be a Problem with the type of Wi-Fi security being used.
imjolly
Message 3 of 6
did you turn off smart setup in hub?  http://bt.custhelp.com/app/answers/detail/a_id/44328/~/what-is-smart-setup-on-the-bt-hub%3F-how-can-...
amcenteggart
Message 4 of 6
Thanks yes you t doesn’t support 5g but turned that off and smart set up to no avail - going to replace it with a better quality brand
Thanks for your help
amcenteggart
Message 5 of 6
Yes that’s the first thing I did thanks
VeteranISPUser
Recognised Expert
Message 6 of 6
Hi @amcenteggart. It is probably too late but did you try changing the wireless mode http://bt.custhelp.com/app/answers/detail/a_id/56287/~/what-is-the-wireless-mode-feature-on-my-bt-sm...
