Thompson218
Message 1 of 2
Installing BT NetProtect Plus
I was hoping it would auto uninstall Norton but it didn't so I had to do it myself, unfortunately the uninstall required a reboot and the Net Protect install did not pickup from where it had left it so had to start again including a 160MB download. Anyone know where the previous download went so I could use that?
Thanks.
1 REPLY 1
Distinguished Guru
Message 2 of 2
Re: Installing BT NetProtect Plus
Hi Thompson218 and welcome
It should be somewhere like this (but it depends on your operating system)
Click Start, go to Documents and click it.
Look to the left for a file called Downloads and it should be there.
-+-No longer a forum member-+-
