wads125
Message 1 of 2
Internet Cuts Out (Phone Issue)
Hi,
Internet has always been a bit dodgy but it is currently cutting out when the phone rings (has done this in the past but appears to have started again recently). I have also noted the phone lines can be noisy during phone calls as well as testing 17070.
From looking online I have seen that Panasonic phones can mess up the broadband signal which we have - although the router and phones aren't directly next to each other.
I have a Smart Router Type A and we do have Sonos speakers around the house if that makes any difference.
Any help would be great as an incoming phone call means I disconnect from Xbox so therefore doing horrific things to my serotonin levels.
Thanks!
1 REPLY 1
imjolly
Message 2 of 2
Re: Internet Cuts Out (Phone Issue)
if you get noise on quiet line test when using the test socket then you need to report a phone fault to 151
quiet line test with corded phone should be silent
