jeffers1956
Message 1 of 5
Internet connection
My internet connection keeps dropping sometimes only for seconds but it is annoying microsoft diagnosis it says no wireless internet connection wireless router needs resetting then spends five minutes trying but cannot do it  then seconds later  I am connected again.
Anyone had anything similar.
Cheers
Jeffers
4 REPLIES 4
imjolly
Message 2 of 5
Re: Internet connection
does the light on your hub change colour when this happens
have you checked your line  dial 17070 option 2  should be silent and best with corded phone
jeffers1956
Message 3 of 5
Hi Imjolly,
No the light does not change on the hub I had not checked my line but when I did it just kept repeating quiet line test so after a good few 7 or 8 I put the phone down and the phone is cordless.
Cheers.
imjolly
Message 4 of 5
If the hub light is not changing colour then internet connection appears ok and it is your wireless that is dropping
can you post hub stats. Advanced settings then technical log information
have you tried selecting channels manually instead of leaving on automatic?
have you tried using wifi analyser to see the networks roundabout you and channels in use so you can select a free or less congested channel
quite line test sounds ok from your description
jeffers1956
Message 5 of 5
Hi imjolly,
Thanks I have loaded a wifi analyser and changed the wifi channel from 1 to 11 as recommended by the analyser hopefully this will do the trick but if not I will be back looking for more help.
Cheers
Jeff.
