Message 1 of 12
Internet devices won't reconnect automatically
I converted to BT full fibre (150 mb/s) around 9 months ago, approx. & 3 months after we moved house. Our router connection seems to be getting increasingly problematic with the hub resetting rather more often than I think it should & then, around once every 7-10 days, a reset results in completely losing our laptop computer’s internet connection, our (several) Smart TV connections &, more often than not, our Ring security system goes off-line. I’ve noticed this usually happens overnight & doesn’t seem to affect our mobile phone connections. I never experienced this problem on our part fibre connection in Norfolk or our initial 3-month copper connection her in Essex.
The hub lights always show it’s reconnected automatically but running the trouble shooter on my disconnected laptop displays “no valid IP address”. Resetting the hub does not cure the problem & I then have to re-start our computers & go around the house resetting/re-logging all our internet devices back onto the hub; this is very inconvenient & surely not normal, any ideas please?
11 REPLIES 11
Message 2 of 12
Re: Internet devices won't reconnect automatically
That doesn't sound like normal behaviour, I would ring 0800 800 150 and report it as faulty
Anonymous
Not applicable
Message 3 of 12
When you say you reset the Hub, was that a full reset with a paper clip or just a power cycle? If the latter try the former.
If you have fully reset it then it sounds like an issue with the DHCP server, & I agree with seeking a replacement.
Message 4 of 12
I think you may find that the home hub`s DHCP table entries never expire, so you can end up with no available allocations. This is made worse if you have any Apple devices with private addressing enabled, as that results in a different MAC address/IP address being allocated each time. You will see lots of "unknown device" entries.
The only way to clear out the DHCP table, is by doing a full factory reset of the home hub whenever the problem re-occurs.
Message 5 of 12
@Keith_Beddoe
Just for info, Android devices also use private MAC addressing now by default, the only difference being that they call it "Privacy" (Use randomised MAC).
Message 6 of 12
Yes, I noticed that on the latest Android releases. Its going to cause a lot of issues, and also make parental controls useless on the home hubs and many other routers that do not have the option to create MAC "whitelists", so that only the connecting device true MAC device can connect, which means turning MAC randomisation off.
Message 7 of 12
I tried turning it off on my own phone but it just seems to restore itself. We also have other Android devices in the house and consequently I have to keep going through the network manager on my hub deleting all the "Unknown" devices 😠
Message 8 of 12
I recently had to do full reset (related to the same problem) in order to get everything to reconnect to the hub, this is covered on an earlier thread.
Message 9 of 12
Done full reset previously on same problem as I couldn't get anything to work properly but why does the problem keep occurring every 7 to 10 days or so?
Message 10 of 12
That is probably the time it takes for the home hub DHCP to run out of connections.
How many devices do you have, which have the Private Address option enabled? You would be better to turn that feature off, and just let the device MAC address present itself, as that would stay the same every time it connects, and the device will also be given the same IP address each time.
