Carl_Smyth
Message 1 of 16
Internet issues
Hey,
Posting here as I am out of ideas. I am a BT Plus customer. Been with BT for years with no issue. About 1 month ago I started getting high MS/Ping spikes at random times of the day (not at just peak times, anytime really). I though nothing of it as I had not had issues for years but they kept persisting. I eventually opened a fault and got a engineer out.
Long story short...6 engineer visits later and the issue still persists. The real problem I am having is that i cant make the fault happen, it just happens randomly therefore evertime a engineer comes and connects his equipment to my masterbox there is no issues and when he looks at my line speed on his mobile for the last few weeks for example it shows the speed is stable...I just dont get it. How can I be experiencing these issues but on BT's side everything is 'fine'.
My usual speeds are around 40mb down and 6.6mb up with around 40ms ping. However when I get spikes my ms will jump up to 600-1300ms and if I do a speed test (not only on various 3rd party speed test webistes but also on the BT wholesale site) my speed goes drastically down, i.e 10mb down 0.3mb up etc etc. This has been happening for over a month now with no fix in sight. The spikes will last around 20mins then will calm down and go back to normal for a bit and then another spike will happen etc etc.
Some more Info, I have had the following done by Engineers.
  • Line from mastersocket to telephone pole replaced.
  • Router replaced.
  • Tried the router connected Wirelessly and via a cable (to rule out a faulty cable)
  • Replaced every cable/filter possible
  • Ports at the exchange replaced
  • Engineer put me on different lines (in the ground)
I am at a loss right now and im in a contract with BT until November and basically been told as far as they are concerned the line is stable and fine and there really isnt anything else I can do. I do wonder where the BT wholesale results go to when it says 'Uploading to server' as if they had access to that info I have done 20+ Speed tests on there showing my issue.
Any suggestions would be appreciated as I am at a loss what to do going forward as I am a avid gamer and am unable to do anything right now due to these constant spikes.
Carl Smyth.
15 REPLIES 15
Carl_Smyth
Message 2 of 16
Re: Internet issues
Carl_Smyth
Message 3 of 16
Re: Internet issues
As you can see my speeds are all over the place....
Carl_Smyth
Message 4 of 16
Re: Internet issues
Message 5 of 16
Re: Internet issues
can you post stats from your hub. If hh6 then advanced settings then technical log information
if hh5 then troubleshooting then helpdesk
Any noise on line dial 17070 option 2 should be silent and best with corded phone
only the last btspeedtester test is help on server - each test supersedes the previous test
Carl_Smyth
Message 6 of 16
Re: Internet issues
Carl_Smyth
Message 7 of 16
Re: Internet issues
No noise on the line
Message 8 of 16
Re: Internet issues
So from stats your connection has been stable for 3 days plus
Carl_Smyth
Message 9 of 16
Re: Internet issues
This is the thing though, its not stable. As you can see from the test results i posted multiple times my speed and MS is all over the place. I get constant spikes all the time no matter what part of the day it is and I just lose all speed. What could be causing this if its not the internet? its not like it happens if i play a particular game or something, I can just be watching a youtube vid and suddenly it starts buffering so I do a speed test to see what happening and I get results like I posted.
Message 10 of 16
Re: Internet issues
Your line and therefore your connection is stable from your stats  however what you describe is download problems which is different  does your download problem happen when using just wireless? Does it happen at peak time but ok at off peak?
