ChrisB
Expert
Message 31 of 348
Re: Introducing Complete Wi-Fi from BT
But NOT an Android tablet update.
Distinguished Expert
Message 32 of 348
It’s all mysterious.
I checked again on the iPhone 8.
There was an update found by searching in the Apple store and tapping “update”. Yet it was working before the update. Not so on the iPad,which gave a warning.
Can you do an app search on your tablet?
ChrisB
Expert
Message 33 of 348
I've had it loaded on my (Android) tablet for some time but it stopped working (yesterday) and said the tablet was incompatible. It told me to go to the App Store (sic). Play Store just says the tablet is incompatible. It works on my (Android) phone.
Message 34 of 348
It’s one for our BT Devices Expert, then.
If it’s any consolation, the iPad MyBt app ceased working only today, and a warning appeared to go to the App Store.
So is the latest update at fault?
BT Devices Expert
BT Devices Expert
Message 35 of 348
Hi @ChrisB @Ribblelancs - I've raised the App issues with the dev team.  I'll keep you updated.
@ChrisB - if you go to this page - https://www.productsandservices.bt.com/broadband/complete-wifi - and choose the - existing customer "see your deals" - link, you'll log into your account and get to the deals for you.
Thanks for the info
Cheers
Luke
Devices expertLukeB
Show your appreciation!
Kudos”Kudos”
Message 36 of 348
Here's the latest status of My BT app on my devices:-
Mobile, Galaxy S5, Android 6.0    My BT version 8.0.7, updated today, 11-00am.
Iphone, ipad, ios 12.1                      My BT version 8.0.9, updated yesterday.
All working correctly.
alan_mc
Message 37 of 348
So, my current setup is that my smart hub is in my integrated garage as that's where my builder decided to put the master socket.  I then use a TP-Link RE200 Range Extender so that i have ethernet going into my you view box and devices (xbox, now tv etc) upstairs wireless on a 3 bed house.
Question? - Do the extender disks have ethernet ports on them, i.e. to connect my youview box to and remove the TP Link Extender or will the TP link extender still work with the Smart Hub 2 / Disks.
Also, I wanted to know what benefits the new hub has over the old.
In comparing the results from the test at https://img01.products.bt.co.uk/content/dam/bt/storefront/pdfs/smart_hub_claims_substantiation.pdf
for my given setup (removed Room A as no devices in there and Room D as only ground and 1st floor), it seems the Smart Hub 2 offers some key wins and where it doesn't, the difference between the two is marginal (but at my connection speed of 17-26mb, i'm unlikely to see any significant benefits.)
3.1. Over-the-Air 2.4GHz coverage results
Without interference
2.4GHz MacBook Pro download test
RouterRoom BRoom CResult Smart Hub 2 Difference
BT Smart Hub 2147.20108.67Smart Hub 2 2.5317.10
BT Smart Hub144.6791.57
2.4GHz Samsung S8 download test
BT Smart Hub 2129.4065.35Smart Hub 2 12.9018.88
BT Smart Hub116.5046.47
2.4GHz MacBook Pro upload test
BT Smart Hub 2120.6746.22Smart Hub -1.33-3.13
BT Smart Hub122.0049.35
2.4GHz Samsung S8 upload test
BT Smart Hub 293.3533.00Smart Hub -5.72-1.40
BT Smart Hub99.0734.40
3.2. Over-the-Air 5GHz coverage results
5GHz MacBook Pro download test
RouterRoom B Result
BT Smart Hub 2336.00 Smart Hub 2 19.67
BT Smart Hub316.33
5GHz Samsung S8 download test
RouterRoom B Result
BT Smart Hub 2288.25 Smart Hub 2 86.25
BT Smart Hub202.00
5GHz MacBook Pro upload test
RouterRoom B Result
BT Smart Hub 2220.33 Smart Hub 2 6.33
BT Smart Hub214.00
5GHz Samsung S8 upload test
RouterRoom B Result
BT Smart Hub 2156.75 Smart Hub -7.25
BT Smart Hub164.00
Coverage testing with interference
MacBook Pro download test with interference
Router Room CResult
BT Smart Hub 2 81.94Smart Hub  -2.27
BT Smart Hub 84.21
Samsung S8 download test with interference
Router Room CResult
BT Smart Hub 2 48.10Smart Hub 2  6.68
BT Smart Hub 41.42
MacBook Pro upload test with interference
Router Room CResult
BT Smart Hub 2 38.91Smart Hub  -0.67
BT Smart Hub 39.58
Samsung S8 upload test with interference
Router Room CResult
BT Smart Hub 2 26.86Smart Hub  -1.40
BT Smart Hub 28.26
Question - Is it worth getting the New Hub based on the information above?
northshields
Message 38 of 348
I could be very interested in this offer, but before jumping in I have a couple of questions.
1. I cuurently have a HH5A which, as is well known, has the irritating habit of automatically re-booting every 14 days. Does the new hub do the same?
2. What is the procedure for getting extra discs? Given the size and construction of my house, I would probably need 2 discs.
BT Devices Expert
BT Devices Expert
Message 39 of 348
Hi  @alan_mc - the info we've posted online is just for the Smart Hub & Smart Hub 2.
The biggest benefit of Smart Hub 2 is moving to Complete Wi-FI then you get much faster speeds in Room C / D - I'll drop through some more specific data points a little later.  Do you need better wi-fi than you've got with your current Smart Hub?
We don't recommend / support using the Wi-Fi Discs for BT TV (yet... we may in the future but want to make sure it'll work brilliantly) - if your current setup's working - I'd recommend keeping it as is
Devices expertLukeB
Kudos”Kudos”
BT Devices Expert
BT Devices Expert
Message 40 of 348
Adding to my reply for  @alan_mc
... I recommend... keeping your TV setup as is
... But, if you need a faster wi-fi signal at distance in your home... Complete WI-Fi, with the Discs will provide a better experience
Devices expertLukeB
Kudos”Kudos”
