Message 221 of 382
Re: Introducing Complete Wi-Fi from BT
@ribbielancs, yes smart setup is off, but the sky q wifi setup doesn't offer channel 48 so no way that could work.
I'll look at changing the wireless mode though.
Not sure how many have sh2 and a sky q silver set up
Distinguished Expert
Message 222 of 382
If you are using Windows(10), there’s a good network analyser free app.
It gives you a good insight of which channels are in use. It shows hidden channels also.
It’s the hub which you must set at ch 48, not the sky box. A problem with conflicting mesh networks, perhaps.
Perhaps the BT expert may comment and give some very useful advice.
Message 223 of 382
Had an issue this morning whereby everyone's wifi connection completely vanished. Mobile devices, printer, basically everything over wifi, the signal would vanish and come back a few seconds later and kept on doing this for a few mins before stopping. 20 mins would pass before it would happen again! I've pulled the power from the router & disc so hopefully this will resolve. Weirdly there was no indication on the router or disc (lights) that there was an issue.
Message 224 of 382
@ribbielancs
been there, it the sky q box it only offers certain channels and channel 48 isn't one of them.
I had tried channel 44 but that affected the sky connection thus delving into the configuration further.
I'd still love to know why the sh2 isn't saying why devices that support dual band don't accept it.
come on BT engineers I know you are reading this.
BT Devices Expert
BT Devices Expert
Message 225 of 382
Hi @Oemoore64 and @jaymorley
I've been on hols!  Sorry 😉 - I had a good time 🙂
I've dropped a note to my tech team who'll be in touch with you guys - we'd love to look into both of your issues and understand what's happened and sort.
Cheers
Luke
Moderator
Moderator
Message 226 of 382
Hi @Oemoore64 and @jaymorley Sorry you are experiencing problems with the Complete Wifi.
I've sent you both a Private message explaining how you can contact the forum moderation team. check here
https://community.bt.com/t5/notes/privatenotespage
Cheers
John
Message 227 of 382
All good now thanks.
Moderator
Moderator
Message 228 of 382
Hi @3068152008  thanks for the update and good the hear all is well now.
Cheers
John
Message 229 of 382
I believe that someone tried to call me, but I am on work calls till 5pm
Moderator
Moderator
Message 230 of 382
Hi @Oemoore64 It was @RobbieMac who called. He was just letting you know he had picked up your case. He has contacted product experts for advice on your case and will update you as soon as he hears back from them.
cheers
John
