Montala
Message 281 of 471
Re: Introducing Complete Wi-Fi from BT
@Ribblelancswrote:
@Montalawrote:
Hi Sean,
I will start by admitting that I haven't read every single post in this thread, but I have just set up a new BT Complete Wi-Fi system using a Smart Hub 2 router, with a couple of Wi-Fi discs.
Can I ask if there has been a firmware update for this router recently, and if so what is the latest version to be released, as I am sure that mine has changed within the last few days.
Thanks! Smiley Happy
The firmware updates a day or so after initial install.
Firmware is Vo12.02.11078-BT
Thank you... that is the version I have!
Can I ask when that one was actually released please?
Paul_31
Message 282 of 471
@Montala I think it was released around 20/21 January. That’s when my system got updated.
tractorgirl2
Message 283 of 471
I posted a few days ago about discs daisychaining together to reach far flung extremities of the house. Well I'm having no luck (and to be fair I am trying to reach an annex which is separated from the house by circa 3 metres) so......
Plan B - any known problems/reason not to use powerline adapters to reach the annex alongside complete wifi in the main house?
Just checking before I buy something else which may not work, as I could probably have lived without complete wifi in the house, but had been hoping it might just reach the annex!
MTA
Message 284 of 471
@tractorgirl2  If the PLA in the annex is on the same ring main as the house it should work. You can plug an ethernet cable into the back of the disc and a PLA in the annex, then in the house do the same to the SH2 - eth cable from SH2 to PLA
tractorgirl2
Message 285 of 471
Thanks for the response - thought I'd better check just in case there was some known incompatibility between complete wifi and powerline adapters. Will check the ring main question with the electrician.
malnichol
Message 286 of 471
With the disc can I plug a ethernet cable into it and then into my tv whilst at the same time use the disc for wifi also or is it a either or situation.
VeteranISPUser
Recognised Expert
Message 287 of 471
Hi @malnichol   I use Ethernet connected to my Disc with several devices also connected by WiFi to it. So the simple answer is yes.
malnichol
Message 288 of 471
Many thanks
Montala
Message 289 of 471
Thanks for the information Paul_31... your reply is appreciated.
malnichol
Message 290 of 471
Well I have been messing about for a week now and I cannot seem to get my wifi to work as good as the SmartHub 1. The range with the discs is better but sitting connected to my synology nas in my living room about 7 feet from my SH2 the video is buffering on the wireless connection. This never happened on my SH1 am I doing somthing wrong.
Things I have tried
1. Turned off smart channels on SH2
2. Rebooted my Mac, SH2 and my Nas
3. Deleted my Network profile on my Mac and set it back up again.
I am convinced that it is the SH2 as the SH1 always reached download speeds of 61-65MB with SH2 the download speed ranges from 37-64MB. This is using OKLA Broadband Speed Test. The speed test to the hub using BT app shows 65MB download speed. If that is correct then it appears to be my wifi has reduced on the SH1.
Any ideas other than going back to the old SH how to rectify this?
Thanks MN
