dephead2004
Message 471 of 471
Re: Introducing Complete Wi-Fi from BT
Thanks. It is EE and they are now owned by BT! hence the tie up.
I'lll try a long network cable. Removed the BT wall plug to test the hybrid and it worked as expected. So then -117dB works
