@Oemoore64 wrote:
@ribbielancs, yes smart setup is off, but the sky q wifi setup doesn't offer channel 48 so no way that could work.
I'll look at changing the wireless mode though.
Not sure how many have sh2 and a sky q silver set up
If you are using Windows(10), there’s a good network analyser free app.
It gives you a good insight of which channels are in use. It shows hidden channels also.
It’s the hub which you must set at ch 48, not the sky box. A problem with conflicting mesh networks, perhaps.
Perhaps the BT expert may comment and give some very useful advice.
Hi @Oemoore64 and @jaymorley
I've been on hols! Sorry 😉 - I had a good time 🙂
I've dropped a note to my tech team who'll be in touch with you guys - we'd love to look into both of your issues and understand what's happened and sort.
Cheers
Luke
Hi @Oemoore64 and @jaymorley Sorry you are experiencing problems with the Complete Wifi.
I've sent you both a Private message explaining how you can contact the forum moderation team. check here
https://community.bt.com/t5/notes/privatenotespage
Cheers
John
All good now thanks.
Hi @Oemoore64 It was @RobbieMac who called. He was just letting you know he had picked up your case. He has contacted product experts for advice on your case and will update you as soon as he hears back from them.
cheers
John
