sg28
Newbie
Message 1 of 4
Ip address bt home hub 4.0
Hi can some one please advise... I would like to change my ip address with in the router , if i click the disconnect button in the bottom right hand corner what are my next steps?
Thanks in advance
3 REPLIES 3
Message 2 of 4
Re: Ip address bt home hub 4.0
Turn the router off for about 15 mins. When it reconnects it will probably have a been issued with a new IP address.
sg28
Newbie
Message 3 of 4
Thanks for the reply. I would like to change the ip settings to an overseas IP address
Thanks once again
Message 4 of 4
You have no say in what IP address you get. You are allocated a dynamic IP address by BT.
If you want to use over seas websites you should consider signing up to a VPN service.
See links about VPN
https://www.howtogeek.com/133680/htg-explains-what-is-a-vpn/
https://en.wikipedia.org/wiki/Virtual_private_network
