dgw1
Message 11 of 15
Re: Is my home hub 4 faulty?
How are your security cameras connected to your hub? Do you have anything else plugged in to the same sockets. extension leads as your camera system?
offgridlee
Message 12 of 15
The camera is a usb webcam connected to a raspberry pi. The raspberry pi is connected to the hub via an ethernet cable. No other devices are connected to the hub either wirelessly or through the ethernet.
The raspberry pi uses Motion to stream the images to a webserver running on the raspberry pi itself, I access the raspberry pi web server from the internet by port forwarding.
When the hub suffers the green light boot problem the Customised settings within the hub are lost and I have to restore the settings from a backup, I.e I have to re set up port forwarding, dynamic dns settings etc from the hub manager.
Message 13 of 15
I would not spend any more time with the home hub, save yourself a lot of hassle and get a different router.
One of these works just fine, I have a number of ports forwarded without any problems, Its also very stable and not under the control of BT.
Cheap reliable replacement for home hub.
offgridlee
Message 14 of 15
I had a look at the specs of the TP-Link TD-W9970 N300, it looks perfect for what I need. I'll give it a try.
I think that's the solution instead of wasting any more time on the home hub.
Consider this problem solved!
Message 15 of 15
@Devon_Dave also has one of those routers.
If you need any help, please ask, as I can add additional information to the pages on my website which would be useful to everyone else.
