Message 1 of 3
Is unlimited really unlimited? To be used for streaming 4K TV
Reason for asking, if I buy a 4K tv with a netflix app and use that outside the BT vision box for 4k streaming, it will rack up a lot of data coming down the pipe.
At the moment I have a HH3 and a standard Youview humax (BT Vision) box. This will be changed at some point to take advantage of what BT offers. So I think the only way the TV will work with 4K for now is via it built in app and I hard wire the TV to the router. Hence the concern of what data is used for this until it is resolved by getting the UHD box from BT.
2 REPLIES 2
Message 2 of 3
Re: Is unlimited really unlimited? To be used for streaming 4K TV
Totally unlimited is exactly that.
"At BT our unlimited broadband usage isn’t just restricted to our fibre packages. With both BT infinity fibre broadband and standard BT broadband you can get totally unlimited usage every month and unlike some providers, we won’t slow your broadband down and peak times"
400
Message 3 of 3
Thankyou. Wanted to make sure I was not missing something in the small print.
