Message 11 of 14
Re: Issue with DHCP and IPv4 addresses - some websites not found
Looking at the ChatGPT log, it looks like it's very politely telling you that one of your switches is not a switch, but a router!
Whole house, garden, garage and half the street covered by a Flint 4 - WiFi 7 router
Message 12 of 14
As I said, a blindingly obvious misconfiguration.
Message 13 of 14
Yes. Problem was it’s no longer on the network. I had experimented with using an old router as a switch, trying to turn off the WiFi and router functionality. It didn’t work, so I removed it. However Windows remembered it was there and then couldn’t decide which router to use for DHCP. Crock of ****!
Message 14 of 14
Glad you have sorted it. Network issues can be so frustrating.
Thanks for the link, I have saved the page as there are a few useful commands/ways to do things in the transcript.
Cached addresses/gateways/DNS are so often the problem in network issues. Have found in the past Windows hates the ethernet adapter and wifi both being enabled. It's easy confused, poor little thing 😉  My usual first step in debugging is that something somewhere has been cached.
Maybe obvious I know, but have found that 'forgetting' the network (in wifi config on Windows machines) and then a reboot can be a good way of clearing issues where it's in a muddle. (Always need to make sure you know the password for the WIFI before doing this, just in case anyone is reading this later, and yes I do know people who would blindly do it 😞 ). Once rebooted then selecting the network and connecting to the WIFI again.
I tend to use this as a first step.
