Message 11 of 12
Re: Issues connecting a Nintendo Switch
@Conorb564 wrote:
A Factory reset on my Hub has resulted in the Usual, the switch has disconnected after 1 day of use. I don't know what to do anymore.
That sounds like a DHCP lease expire period. Try increasing the DHCP lease time on the home hub, an see if it remains connected for longer. You may be able to set it up to 21 days.
Message 12 of 12
Hi @Keith_Beddoe
I upped the lease period to 2 days, no luck 😞
