chrisnewman
Message 1 of 2
Issues transferring music from one Apple HomePod to another
Hi all,
Just installed a BT SmartHub (HomeHub 6?) and I'm having issues transferring music from one HomePod to another. Using my old router I could say "Hey Siri move to kitchen or Living Room" and the music would be transferred straight away. If I try that with the SmartHub Siri reports that it can't see a device to support the action.
I've looked in the SmartHub home page and sometimes the devices are on the 5Ghz network and sometimes 2.4 and sometimes with no network allocation. I note there are some issues with peer to peer on BT SmartHub so I'm guessing this is the root cause.
Has anyone else got this issue and able to resolve it? Otherwise it's back to my old router.. TIA
1 REPLY 1
chrisnewman
Message 2 of 2
Re: Issues transferring music from one Apple HomePod to another
Moved back to my old router. Thanks
