Do you also know if the IPTV multicast is distributed across all LAN sockets?
Hi I have a similar issue I think - had a Draytek 2860Vac which I used instead of the BT equipment, was plugged into phone line.
I have now upgraded to BT Ultrafast 250 (same phone line connection) - the engineer didn’t change anything at my house, but cannot get the router to work. Is this because I am on G.Fast ?
He must have changed the faceplate surely if you have moved to GFast/Ultrafast?
if so for Draytek to work you need a GFast modem.
Hi thanks - no, he did everything from the cabinet I guess as didn't actually come to my house. I did have BT broadband Fibre 2 beforehand, with phone line plugged into Draytek router.
Checking online to see what my line now has shows this :
The Draytek won't work with G.fast. You are pretty much restricted to either a BT smart hub or the Asus DSL AC 88U
Got it - thanks for the replies....bring on eBay.
BTW, anyone know if the Netgear Orbi works on G.fast - was thinking of upgrading from my current Apple Extreme coverage. Or do I need to plug the BT router into the Orbi. (or is there a website which provides compatibility)
thanks again
