-Darren-
Message 1 of 2
Jitter when video streaming
Have the same problem as everyone else since december 2018, latency spikes when a video stream is active on the line causing massive jitter that makes online games unpayable. Connection is knowhere near being maxed out by the stream it's not even touching the sides.
Posting this thread at the request of @PaddyB - https://community.bt.com/t5/Home-setup-Wi-Fi-network/Latency-Issue-Ping-Jitter-Whilst-Streaming/m-p/...
C:\Users\*>ping -t bbc.co.uk
Pinging bbc.co.uk [151.101.192.81] with 32 bytes of data:
Reply from 151.101.192.81: bytes=32 time=233ms TTL=57
Reply from 151.101.192.81: bytes=32 time=10ms TTL=57
Reply from 151.101.192.81: bytes=32 time=9ms TTL=57
Reply from 151.101.192.81: bytes=32 time=191ms TTL=57
Reply from 151.101.192.81: bytes=32 time=18ms TTL=57
Reply from 151.101.192.81: bytes=32 time=105ms TTL=57
Reply from 151.101.192.81: bytes=32 time=235ms TTL=57
Reply from 151.101.192.81: bytes=32 time=127ms TTL=57
Reply from 151.101.192.81: bytes=32 time=207ms TTL=57
Reply from 151.101.192.81: bytes=32 time=147ms TTL=57
Reply from 151.101.192.81: bytes=32 time=237ms TTL=57
Reply from 151.101.192.81: bytes=32 time=119ms TTL=57
Reply from 151.101.192.81: bytes=32 time=172ms TTL=57
Reply from 151.101.192.81: bytes=32 time=242ms TTL=57
Reply from 151.101.192.81: bytes=32 time=145ms TTL=57
Reply from 151.101.192.81: bytes=32 time=243ms TTL=57
Reply from 151.101.192.81: bytes=32 time=10ms TTL=57 <----Stopped video stream
Ping statistics for 151.101.192.81:
Packets: Sent = 72, Received = 72, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 9ms, Maximum = 243ms, Average = 43ms
1 REPLY 1
h3x1e
Message 2 of 2
Re: Jitter when video streaming
Could you post some ping plotter screenshots, so we can see each nodes ping, would help with the infomration gathering thats currently helping trace the ping issues (ones that arent being caused by local line issues) in other cases, including mine.
