the2ems
Message 1 of 9
Keep losing connection to printer
About a year and a half ago, I treated myself to a new HP wireless air printer. I had no problems printing from my iPad, iPhone, or computer. Then I changed broadband provider from Virgin to BT. Now it seems that every time I want to print from my iPad, I firstly have to go and restart the router. Grr
8 REPLIES 8
Message 2 of 9
Re: Keep losing connection to printer
If you have the hh6 have you turned off smart setup?  Have you split the networks as many devices do not like them combined
Paul_31
Message 3 of 9
You're not alone... I have an HP Envy 4500 series Airprint printer and it too falls off the network. I've tried all kinds of things to resolve it and the method I've settled on is to let the HP power itself off when not being used (I don't have a continuous need to print things). Now I know that if I do want to print or scan something I have to switch the printer on first, rather than send something to print. find it doesn't print and then have to switch the printer off and then on again .
I know it's not a 'real' solution, but it works for me.
The other more techinical 'fix' that also works (for me at least) is to add and use a new printer using the I.P. protocol. I find this way the printer stays on the network and can print 'on demand'. The only problem with this method is that the scanning option doesn't seem to be available. But for printing only it's fine.
(I only have Macs and other Apple devices connected).
the2ems
Message 4 of 9
the2ems
Message 5 of 9
I have no idea what you are talking about.
Paul_31
Message 6 of 9
@the2ems Are you talking to me? I was trying to help. What part don't you understand - 'switching the printer on', or the I.P. printing bit.
I thought you came here looking for help/suggestions? If you need any clarification on what I posted feel free to ask.
Edit: I can now see that you weren't replying to me, but to do what imjolly suggested log into your router using a web browser. If it is a SmartHub 6 type: 192.168.1.254 into a web address field and it should become clear.
2nd edit: note I've changed the 192.xxx number as I made a typo - it is now correct.
the2ems
Message 7 of 9
I’m glad you edited that. Your initial response was quite aggressive.
Dean007
Recognised Expert
Message 8 of 9
Hi @the2ems
I had the same issue with my HP Laser printer. I had split bands on my HH but it made little difference. In the end after talking to HP support, I just wired it into my BT Whole Home.
Message 9 of 9
@the2ems
which router are you using?  if hh6 then enter hub manager then you can see smart setup and I suggest you turn that off
then go to wireless and move slider to separate networks  if hh6 then tis will change the SSID of 5ghz network by adding a 5  you can now log in to either ot both networks depending on your device  many devices do not like the networks combined
