Message 1 of 5
Keeping old router
Evening all thinking about upgrading to fibre will the fibre work with my old router a net gear dgn1000 I kept this an threw the home hub away about two years ago as I couldn't set it up to my Vodafone sure signal (not needed now)
thanks
4 REPLIES 4
Message 2 of 5
Re: Keeping old router
No. The DGN1000 is an ADSL modem router. You will need a VDSL modem/router.
BT will supply you with the Smarthub.
Expert
Message 3 of 5
No it's an ADSL modem/router.  You will need to get one that supports VDSL.
Message 4 of 5
Thank you for your swift answers will bt send me one of these routers as I have already had one ?
Message 5 of 5
If you are going from "normal" broadband to Infinity they will send you one.
