Guppyfish1
Message 1 of 9
Kindle Fire TV - BT Home Hub Problems - Can't connect
Hi All,
Looking for some help. I have just got the Kindle Fire TV but cannot connect it to the Home Hub 5 like the other posters in this chain.
Edited by mod
Any ideas or help I can see the hub but it will not connect?
GF
8 REPLIES 8
Message 2 of 9
Re: Kindle Fire TV - BT Home Hub Problems - Can't connect
You will need to delete the link. It's against forum rules to post a link to an e-commerce site.
Message 3 of 9
How are you connecting, wired or wireless?
Have you turned off "Smart Set Up" on the Homehub. See link how to do that.
http://bt.custhelp.com/app/answers/detail/a_id/44328/~/switching-smart-setup-on-and-off-on-the-bt-ho...
Guppyfish1
Message 4 of 9
Thanks for the help.
I have tried both wireless and wired. On wired it says it loses connextion or wireless it says it can't find amazon.co.uk.
I will try turning off the smart set up and let you know.
GF
Message 5 of 9
Do you have any parental controls set up on the Homehub?
Guppyfish1
Message 6 of 9
Turning off auto set up has worked.
Thanks for your help most appreciated Cat Happy
GF
Message 7 of 9
You should post it onto the site that you had linked to in your first message.
Yipyop
Newbie
Message 8 of 9
This worked instantly for me too. Big help, thanks so much!
Yipyop
Newbie
Message 9 of 9
