Message 1 of 7
L2TP vpn not working
l2tp/ipsec with pre-shared key not working since moving from copper wire to bt fibre; has anybody got a solution please
6 REPLIES 6
Message 2 of 7
Re: L2TP vpn not working
Did you also change routers? My previous employer used L2TP VPN on our work laptops. This worked fine using BT Smart Hub 2 on a full fibre connection.
Are you connecting over IPv4 or IPv6 too?
Message 3 of 7
no change, i was already using a BT Smarthub 2 on copper, now on full fibre connection. problems seemed to start when BT started to setup voip
Message 4 of 7
I guess maybe the L2PT may interfer with VOIP, however I have never setup L2PT before.
With the move to FTTP were you generated a new IP address, I know with me, I set my IP manually so any change of IP I would have to change manually in any config files.
Message 5 of 7
how did you set the ipaddress manually and where did you get the ipaddress details ?
Message 6 of 7
I suspect @sukisü  means he set the VPN client config manually to match his public IP address.
I doubt that is your problem as your public IP address would have been dynamic and changed at intervals with your FTTC connection.
Message 7 of 7
is there a possibility that ipaddresses are out of range for the site connecting to, or an issue with the subnet masks ?
