Message 1 of 4
LG NAS not connecting to Smarthub2
Hi
I'm trying to connect my LG N1A1DD1 NAS to my hub.
It is a IPv4 device and is connected to the hub by cable
it is listed in the device list but the font is light grey and not bold as are items that are working OK
Using the IP address in the device list when I "ping" I get "host not reachable"
Suggestions please
3 REPLIES 3
Message 2 of 4
Re: LG NAS not connecting to Smarthub2
@teka
What port are you connecting the NAS to on the SH2? Typically port 4 is set up for Full Fibre although that can be switched off in settings.
Are you assigning the NAS a permanent IP address within the NAS or using DHCP in the SH2?
Message 3 of 4
Thanks for msg
Was using port 4, have moved to port 1 - ping result is the same
On hub manager network the diagram shows nothing connected to ports 1,2,3 or 4
Under the list of devices for the NAS it shows port 1 and the IP address - this doesn't change when move cable to another port. This is the address I have tried to ping
I haven't assigned any addresses
Message 4 of 4
Factory reset the NAS and the hub and try again.
