Message 1 of 5
Laptop connected to BT broadband but doesn’t have internet connection
Hi
My laptop can connect to BT broadband with strong signal but doesn’t have internet connection.
Thanks.
4 REPLIES 4
Message 2 of 5
Re: Laptop connected to BT broadband but doesn’t have internet connection
Are you connecting to your own BT broadband SSID or are you trying to connect to BTWIFI?
Message 3 of 5
My own BT broadband in my room.
Message 4 of 5
Are you connected via WiFi or using an ethernet cable?
Are there any other devices connected to your router?
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
Message 5 of 5
@leepy8039
You could try right-clicking on the internet icon, bottom left and selecting "Troubleshoot" to see if anything is reported.
If you left-click on the same icon and ensure it is YOUR Hub you are connecting to. While there, ensure you're not in "Flight mode"!!!
