Moderator
Moderator
Message 21 of 26
Re: Latency Issue - Ping Jitter Whilst Streaming
Hi @Bloodraven,
I gave your mobile number a quick call, I'm sorry I didn't get speaking to you. The reason for my call was to see how things are with your connection.
I can see that your current session has been active for the last 9 days. Have you had a chance to connect your router to the master socket?
PaddyB
Message 22 of 26
@PaddyB I can take the call just missed it by 2 seconds and ringing back the number doesn't do anything.
Still having the issue and I haven't plugged it into the inside of the master socket yet.
Moderator
Moderator
Message 23 of 26
Hi @Bloodraven,
I've run a few checks on your line and your connection is looking a lot better in terms of error now that the location of the router has changed. I've requested a profile reset with Wholesale and this should see the interleaving reduce on your line.
Please, can you reset your connection over the weekend and let me know if you've seen an improvement?
PaddyB
Message 24 of 26
This is a problem for many people mate there is no fix for it, Just BT being BT, they say they are away of the issue and are trying to fix it so they say.
https://www.ispreview.co.uk/index.php/2019/08/customers-of-uk-isp-bt-see-multiplayer-lag-spikes-duri...
Message 25 of 26
@PaddyB Here are some screenshots of how its been today
Earlier today with BBC iPlayer going (not sure on what the bitrate is for iPlayer)
And here is an idle network test which happened to be running whilst I was talking to you on the phone just now
Message 26 of 26
What do you use to make those graphs? I want to evidence my (same) issue. Any streaming =wildly fluctuating ping
