Keith_Beddoe
Message 41 of 64
Re: Will an asus router fix my issues?
I hav just run a test for you, on my ADSL connection.
Before starting YouTube video.
C:\Users\Keith>ping -t bbc.co.uk
Pinging bbc.co.uk [151.101.64.81] with 32 bytes of data:
Reply from 151.101.64.81: bytes=32 time=14ms TTL=58
Reply from 151.101.64.81: bytes=32 time=12ms TTL=58
Reply from 151.101.64.81: bytes=32 time=13ms TTL=58
Reply from 151.101.64.81: bytes=32 time=15ms TTL=58
Reply from 151.101.64.81: bytes=32 time=17ms TTL=58
Reply from 151.101.64.81: bytes=32 time=16ms TTL=58
Ping statistics for 151.101.64.81:
    Packets: Sent = 19, Received = 19, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
    Minimum = 12ms, Maximum = 17ms, Average = 13ms
Now with YouTube playing
No difference on my 10Mb download  800Kbs upload connection.
IBanksy
Message 42 of 64
Thanks for the quick response @Keith_Beddoe
This is mine
Connection type:
Fibre Broadband (VDSL)
Before Youtube Video:
C:\Users\Banksy>ping bbc.co.uk -t
Pinging bbc.co.uk [2a04:4e42:400::81] with 32 bytes of data:
Reply from 2a04:4e42:400::81: time=5ms
Ping statistics for 2a04:4e42:400::81:
Packets: Sent = 24, Received = 24, Lost = 0 (0% loss),
Minimum = 5ms, Maximum = 5ms, Average = 5ms
Now with Youtube Playing:
Reply from 2a04:4e42:400::81: time=144ms
Reply from 2a04:4e42:400::81: time=142ms
Reply from 2a04:4e42:400::81: time=6ms
Reply from 2a04:4e42:400::81: time=10ms
Reply from 2a04:4e42:400::81: time=210ms
Reply from 2a04:4e42:400::81: time=179ms
Reply from 2a04:4e42:400::81: time=196ms
Reply from 2a04:4e42:400::81: time=134ms
Reply from 2a04:4e42:400::81: time=58ms
Packets: Sent = 36, Received = 36, Lost = 0 (0% loss),
Minimum = 5ms, Maximum = 210ms, Average = 33ms
This is on a 67.94MBPS Download and a 17.34MBPS Upload connection.
Keith_Beddoe
Message 43 of 64
The difference may be that you are using IPv6 and I am using IPv4. Can you disable IPv6 and try again?
I am not sure if YouTube has IPv6 addresses, so there could be some network translation taking place, which is slowing things down on the upload path?
IBanksy
Message 44 of 64
Disabled IPV6 on my windows PC. Doesn't seem to have made a difference. Thank you for your help btw @Keith_Beddoe
Results with YouTube playing:
Pinging bbc.co.uk [151.101.192.81] with 32 bytes of data:
Reply from 151.101.192.81: bytes=32 time=6ms TTL=57
Reply from 151.101.192.81: bytes=32 time=5ms TTL=57
Reply from 151.101.192.81: bytes=32 time=7ms TTL=57
Reply from 151.101.192.81: bytes=32 time=30ms TTL=57
Reply from 151.101.192.81: bytes=32 time=181ms TTL=57
Reply from 151.101.192.81: bytes=32 time=20ms TTL=57
Reply from 151.101.192.81: bytes=32 time=119ms TTL=57
Reply from 151.101.192.81: bytes=32 time=8ms TTL=57
Reply from 151.101.192.81: bytes=32 time=95ms TTL=57
Reply from 151.101.192.81: bytes=32 time=51ms TTL=57
Ping statistics for 151.101.192.81:
Packets: Sent = 22, Received = 22, Lost = 0 (0% loss),
Minimum = 5ms, Maximum = 181ms, Average = 26ms
IBanksy
Message 45 of 64
C:\Users\Banksy>ping 8.8.8.8 -t
Pinging 8.8.8.8 with 32 bytes of data:
Reply from 8.8.8.8: bytes=32 time=5ms TTL=121
Reply from 8.8.8.8: bytes=32 time=210ms TTL=121
Reply from 8.8.8.8: bytes=32 time=230ms TTL=121
Reply from 8.8.8.8: bytes=32 time=248ms TTL=121
Reply from 8.8.8.8: bytes=32 time=6ms TTL=121
Reply from 8.8.8.8: bytes=32 time=53ms TTL=121
Reply from 8.8.8.8: bytes=32 time=264ms TTL=121
Reply from 8.8.8.8: bytes=32 time=274ms TTL=121
Ping statistics for 8.8.8.8:
Packets: Sent = 28, Received = 28, Lost = 0 (0% loss),
Minimum = 5ms, Maximum = 274ms, Average = 49ms
Keith_Beddoe
Message 46 of 64
It was just a thought. Nothing else you can do, apart from try a different router, to eliminate the HH as being the issue.
You really need to ask other people who are using a different router.
Did you see this post https://community.bt.com/t5/BT-Fibre-broadband/Unstable-connection/m-p/1916891#M283960
IBanksy
Message 47 of 64
@Keith_Beddoe Thanks for your help anyway :). That's quite an interesting article. I saw on that post they are using a Vigor 130 + Asus RT-AC67U router. Do you know why they would use a Vigor 130 ADSL/VDSL2 Modem? Like do you need the modem to be able to use the broadband with a third party router. I also did a BufferBloat test and got a rating of C which is really bad. I was looking at this router which apparently has a good rating for BufferBloat ASUS RT-AC86U Dual-Band AC2900 Wireless Gigabit Router
Keith_Beddoe
Message 48 of 64
I cannot really offer any more advice, as I have no experience with ASUS network stuff, only TP Link routers and Netgear managed switches.
You would need a  VDSL modem/router suitable for gaming. That would have a fast internal processor to shift the data out to the network, without buffering.
You may be able to get some recommendations on this forum.
psykix
Message 49 of 64
Most 3rd party routers do not have a built in DSL modem, hence using a Vigor 130.
I had nothing but issues with the Vigor 130 when I had one, and ended up going back to the Huawei HG612.
The higher end Asus et al routers tend to have some form of QoS, which may help with your traffic management - although if you are the only one on the network and it is still doing it then it is unlikely to be network congestion on your local network.
I'd see if you could temporarily borrow a hub as I don't think a new router will necessarily resolve your issue.
syffuf
Message 50 of 64
Hi all,
I am having the exact same issues here (as a lot of other people from other threads as I can see). Ping spikes up as soon as I use YouTube, Nextflix, Twitch, or even Facebook (while scrolling throught and videos start auto-playing). My internet has been smooth for 2 and so years, and only started noticing this couple months ago - but is now getting worse.
As an example: a ping test when I am scrolling down Facebook:
C:\Users\syffuf>ping -t 8.8.8.8
Reply from 8.8.8.8: bytes=32 time=27ms TTL=121
Reply from 8.8.8.8: bytes=32 time=7ms TTL=121
Reply from 8.8.8.8: bytes=32 time=41ms TTL=121
Reply from 8.8.8.8: bytes=32 time=80ms TTL=121
Reply from 8.8.8.8: bytes=32 time=11ms TTL=121
Reply from 8.8.8.8: bytes=32 time=18ms TTL=121
Reply from 8.8.8.8: bytes=32 time=119ms TTL=121
And one when I am not doing anything apart from ping test:
The sympton is the same if I open an YouTube video or play on Twitch. As soon as I pause a stream, the ping goes back to normal.
Another test I did was to run a speedtest while doing a ping test, and the ping spikes massively;
C:\Users\syffuf>ping -t google.com
Pinging google.com [216.58.198.174] with 32 bytes of data:
Reply from 216.58.198.174: bytes=32 time=6ms TTL=54
Reply from 216.58.198.174: bytes=32 time=94ms TTL=54
Reply from 216.58.198.174: bytes=32 time=52ms TTL=54
Reply from 216.58.198.174: bytes=32 time=61ms TTL=54
Reply from 216.58.198.174: bytes=32 time=58ms TTL=54
Reply from 216.58.198.174: bytes=32 time=67ms TTL=54
Reply from 216.58.198.174: bytes=32 time=62ms TTL=54
Reply from 216.58.198.174: bytes=32 time=57ms TTL=54
Reply from 216.58.198.174: bytes=32 time=64ms TTL=54
Reply from 216.58.198.174: bytes=32 time=65ms TTL=54
Reply from 216.58.198.174: bytes=32 time=29ms TTL=54
Reply from 216.58.198.174: bytes=32 time=215ms TTL=54
Reply from 216.58.198.174: bytes=32 time=25ms TTL=54
Reply from 216.58.198.174: bytes=32 time=113ms TTL=54
Reply from 216.58.198.174: bytes=32 time=166ms TTL=54
Reply from 216.58.198.174: bytes=32 time=125ms TTL=54
Reply from 216.58.198.174: bytes=32 time=174ms TTL=54
Reply from 216.58.198.174: bytes=32 time=91ms TTL=54
Reply from 216.58.198.174: bytes=32 time=156ms TTL=54
Reply from 216.58.198.174: bytes=32 time=216ms TTL=54
Reply from 216.58.198.174: bytes=32 time=150ms TTL=54
Reply from 216.58.198.174: bytes=32 time=161ms TTL=54
Reply from 216.58.198.174: bytes=32 time=144ms TTL=54
Reply from 216.58.198.174: bytes=32 time=223ms TTL=54
Reply from 216.58.198.174: bytes=32 time=111ms TTL=54
Reply from 216.58.198.174: bytes=32 time=7ms TTL=54
If I keep the ping test on while playing a video game, there's no spikes whatsoever, which confirms it's not a bandwidth issue but rather a routing/traffic-prioritization issue.
Did anyone actually manage to resolve this? I see that last suggestions were to buy a 3rd party router with QoS, but did anyone actually buy one and can confirm they solved the issue?
I have been reading about Bufferbloat issues and it does seem to be the cause: http://www.dslreports.com/speedtest/47121856
