StephanieG
Community Manager - Retired
Message 11 of 295
Re: Latency Variation (Ping Spikes) during online gaming.
Hi @h3x1e
I'm really sorry you've having so many problems with your connection.
I see you mentioned that an engineer was due to go out to you. Could you please keep us posted with how that appointment goes?
h3x1e
Expert
Message 12 of 295
Hey @StephanieG , yeah sure.
I'm using this thread to keep a log of everything that's happening tbh 😄
Will keep it updated with any solutions or weird things that happen.
h3x1e
Expert
Message 13 of 295
So this morning I remembered that I hadn't actually tested any other actual streaming websites, such as Mixer.
So I tested a 1080p 60 fps stream on Mixer using the same bandwidth (1MB/s~)
Noticing 1-2ms variance in google pings, and a solid 1.5ms Variance in Battlefield 5 (I use BF5 because it shows variance well)
SO this kinda proves there is something weird happening on BT's network in relation to twitch packets I would assume.
h3x1e
Expert
Message 14 of 295
Testing this morning and the issue is still there however it's not constant again and nothing seems to have changed with the DLM messing with the line.
Instead of constant Latency variation and network icon in BF5 I was actually seeing it stay at 2-3ms variance but still spiking up to 10ms however not constantly.
h3x1e
Expert
Message 15 of 295
hmm, stuff seems to be relatively stable, did notice that DLM had dropped connection and re-balanced though. Still getting the odd spike in ping though.
I have a question though, does a DLM reset actually reset Interleave Delay, currently sitting at 16ms was wondering if a DLM would lower it back to 8ms or could an Openreach Engineer lower than option by itself? I know it would probably screw up the stability right now but...
Current Line Stats.
  ---------------------- ATU-R Info (hw: annex A, f/w: annex A/B/C) -----------
   Running Mode            :      17A       State                : SHOWTIME
   DS Actual Rate          : 30000000 bps   US Actual Rate       :  5602000 bps
   DS Attainable Rate      : 43158344 bps   US Attainable Rate   :  5600520 bps
   DS Path Mode            :  Interleave    US Path Mode         :        Fast
   DS Interleave Depth     :     1549       US Interleave Depth  :        1
   NE Current Attenuation  :       25 dB    Cur SNR Margin       :        3  dB
   DS actual PSD           :     5. 1 dB    US actual PSD        :     5. 2  dB
   NE CRC Count            :        0       FE CRC Count         :    10275
   NE ES Count             :        0       FE  ES Count         :     9798
   Xdsl Reset Times        :        0       Xdsl Link  Times     :       12
   ITU Version[0]          : fe004452       ITU Version[1]       : 41590000
   VDSL Firmware Version   : 05-07-06-0D-01-07   [with Vectoring support]
   Power Management Mode   : DSL_G997_PMS_L0
   Test Mode               : DISABLE
  -------------------------------- ATU-C Info ---------------------------------
   Far Current Attenuation :       36 dB    Far SNR Margin       :        6  dB
   CO ITU Version[0]       : b5004946       CO ITU Version[1]    : 544eb206
   DSLAM CHIPSET VENDOR    : < IFTN >
> v s more
                  Near End        Far End    Note
 Trellis      :      1               1
 Bitswap      :      0               1
 ReTxEnable   :      0               0
 VirtualNoise :      0               0
 20BitSupport :      0               0
 LatencyPath  :      0               0
 LOS          :      6               0
 LOF          :      0               0
 LPR          :      0               0
 LOM          :      0               0
 SosSuccess   :      0               0
 NCD          :      0               0
 LCD          :      0               0
 FECS         :   1132491        39276 (seconds)
 ES           :      0            9798 (seconds)
 SES          :      0               6 (seconds)
 LOSS         :      0             504 (seconds)
 UAS          :     35           32123 (seconds)
 HECError     :      0               0
 CRC          :      0            10275
 RsCorrection :      0               0
 INP          :      0              45 (symbols)
 InterleaveDelay :   0            1600 (1/100 ms)
 NFEC         :    192              55
 RFEC         :     16              16
 LSYMB        :   1539            10664
 INTLVBLOCK   :    192              55
 AELEM        :      0            ----
h3x1e
Expert
Message 16 of 295
So Interleave depth has now been dropped to 549. InterleaveDelay reduced to 8ms, however the ping spikes still exist while watching a stream.
This mornings Line Stats:
   DS Actual Rate          : 30000000 bps   US Actual Rate       :  5545000 bps
   DS Attainable Rate      : 46032808 bps   US Attainable Rate   :  5577288 bps
   DS Interleave Depth     :      549       US Interleave Depth  :        1
   NE Current Attenuation  :       25 dB    Cur SNR Margin       :        5  dB
   NE CRC Count            :        6       FE CRC Count         :    10308
   NE ES Count             :        1       FE  ES Count         :     9830
   Xdsl Reset Times        :        0       Xdsl Link  Times     :       13
   Test Mode               : DISABLE
 Trellis      :      1               1
 Bitswap      :      1               1
 ReTxEnable   :      0               0
 VirtualNoise :      0               0
 20BitSupport :      0               0
 LatencyPath  :      0               0
 LOS          :      8               0
 LOF          :      0               0
 LPR          :      0               0
 LOM          :      0               0
 SosSuccess   :      0               0
 NCD          :      0               0
 LCD          :      0               0
 FECS         :   241434         39388 (seconds)
 ES           :      1            9830 (seconds)
 SES          :      0               6 (seconds)
 UAS          :     28           32154 (seconds)
 HECError     :      0               0
 CRC          :      6            10308
 RsCorrection :      0               0
 INP          :      0              15 (symbols)
 InterleaveDelay :   0             800 (1/100 ms)
 NFEC         :    190              71
 RFEC         :     16              16
 LSYMB        :   1525            9779
 INTLVBLOCK   :    190              71
 AELEM        :      0            ----
One question though, does anyone know if G.INP is enabled on ECI DSLAMs now? I notice that ReTx is showing as disabled when looking at the modem stats but when I check the setting  with "vdsl optn retx" in the Vigor 130 it shows as "[US] = ON,  [DS] = ON"
h3x1e
Expert
Message 17 of 295
Update:
Openreach Engineer just left, told him everything that was going on. Showed him Ping Plotter without a stream running and also with a stream running. He could see the packet loss and sometimes no response from BT hops.
He understood what was happening and advised that he would write up a report and escalate the fault. Advised that I would receive contact within the next 24 hours with information on what will happen next.
He advised that they'll probably send out a Fiber Engineer plug in all the test equipment again and do the exact same thing, but that engineer could then go to the Street Cabinet / Exchange and see if there's anything causing issues there.
Real nice guy, understood that it was an issue for us and that the issue was actually an issue however rare.
We shall wait and see what BT does next I guess.
h3x1e
Expert
Message 18 of 295
@StephanieG Hey, so I've just checked the Fault Tracker, and BT have marked it as fixed. When that was not what the case, as the Engineer said.
Any possibility of looking into this for me?
h3x1e
Expert
Message 19 of 295
Also have another concern now.
We thought Netflix was having issues where it wouldn't load the main /browse page at all. (Where you select what user you want to log in as).
It started around the same time this issue did and it's happening again now...
The website wont load at all in some cases, and in others it will just load the HTML version of the website. (no images or anything)
Checked fast.com and there doesn't seem to be a speed issue there.
h3x1e
Expert
Message 20 of 295
Update: More pings showing the massive spikes.
