lolowalsh
Message 31 of 295
Re: Latency Variation (Ping Spikes) during online gaming.
I won't even dare to touch overwatch with a BT internet unless you want to be banned from competitive. I will feel bad  for ruining other players experience with my ping spikes which is not fair I wouldn't want people ruin my experience either.
Fifa is the most game where I get the most ping spikes, sometimes I can manage playing quickplay on overwatch with a ping with 40 ms when someone watches YouTube, but fifa man it's impossible to play.
h3x1e
Expert
Message 32 of 295
Another day another Graph for you to have a look at 🙂
h3x1e
Expert
Message 33 of 295
Today, you get a normal ping via terminal.
h3x1e@Kings-WS:~$ ping -4 google.co.uk
PING google.co.uk (216.58.210.35) 56(84) bytes of data.
64 bytes from lhr25s11-in-f35.1e100.net (216.58.210.35): icmp_seq=1 ttl=54 time=18.9 ms
64 bytes from lhr25s11-in-f35.1e100.net (216.58.210.35): icmp_seq=2 ttl=54 time=18.7 ms
64 bytes from lhr25s11-in-f35.1e100.net (216.58.210.35): icmp_seq=3 ttl=54 time=18.4 ms
64 bytes from lhr25s11-in-f35.1e100.net (216.58.210.35): icmp_seq=4 ttl=54 time=57.2 ms
64 bytes from lhr25s11-in-f35.1e100.net (216.58.210.35): icmp_seq=5 ttl=54 time=46.5 ms
64 bytes from lhr25s11-in-f35.1e100.net (216.58.210.35): icmp_seq=6 ttl=54 time=18.8 ms
64 bytes from lhr25s11-in-f35.1e100.net (216.58.210.35): icmp_seq=7 ttl=54 time=53.0 ms
64 bytes from lhr25s11-in-f35.1e100.net (216.58.210.35): icmp_seq=8 ttl=54 time=19.5 ms
64 bytes from lhr25s11-in-f35.1e100.net (216.58.210.35): icmp_seq=9 ttl=54 time=19.7 ms
64 bytes from lhr25s11-in-f35.1e100.net (216.58.210.35): icmp_seq=10 ttl=54 time=19.1 ms
64 bytes from lhr25s11-in-f35.1e100.net (216.58.210.35): icmp_seq=11 ttl=54 time=19.0 ms
64 bytes from lhr25s11-in-f35.1e100.net (216.58.210.35): icmp_seq=12 ttl=54 time=18.5 ms
64 bytes from lhr25s11-in-f35.1e100.net (216.58.210.35): icmp_seq=13 ttl=54 time=18.7 ms
64 bytes from lhr25s11-in-f35.1e100.net (216.58.210.35): icmp_seq=14 ttl=54 time=55.4 ms
64 bytes from lhr25s11-in-f35.1e100.net (216.58.210.35): icmp_seq=15 ttl=54 time=45.3 ms
64 bytes from lhr25s11-in-f35.1e100.net (216.58.210.35): icmp_seq=16 ttl=54 time=56.9 ms
64 bytes from lhr25s11-in-f35.1e100.net (216.58.210.35): icmp_seq=17 ttl=54 time=46.9 ms
64 bytes from lhr25s11-in-f35.1e100.net (216.58.210.35): icmp_seq=18 ttl=54 time=18.5 ms
64 bytes from lhr25s11-in-f35.1e100.net (216.58.210.35): icmp_seq=19 ttl=54 time=18.4 ms
64 bytes from lhr25s11-in-f35.1e100.net (216.58.210.35): icmp_seq=20 ttl=54 time=18.9 ms
64 bytes from lhr25s11-in-f35.1e100.net (216.58.210.35): icmp_seq=21 ttl=54 time=18.9 ms
64 bytes from lhr25s11-in-f35.1e100.net (216.58.210.35): icmp_seq=22 ttl=54 time=19.1 ms
64 bytes from lhr25s11-in-f35.1e100.net (216.58.210.35): icmp_seq=23 ttl=54 time=18.4 ms
64 bytes from lhr25s11-in-f35.1e100.net (216.58.210.35): icmp_seq=24 ttl=54 time=51.9 ms
64 bytes from lhr25s11-in-f35.1e100.net (216.58.210.35): icmp_seq=25 ttl=54 time=46.0 ms
64 bytes from lhr25s11-in-f35.1e100.net (216.58.210.35): icmp_seq=26 ttl=54 time=55.6 ms
64 bytes from lhr25s11-in-f35.1e100.net (216.58.210.35): icmp_seq=27 ttl=54 time=51.0 ms
64 bytes from lhr25s11-in-f35.1e100.net (216.58.210.35): icmp_seq=28 ttl=54 time=18.7 ms
64 bytes from lhr25s11-in-f35.1e100.net (216.58.210.35): icmp_seq=29 ttl=54 time=18.8 ms
64 bytes from lhr25s11-in-f35.1e100.net (216.58.210.35): icmp_seq=30 ttl=54 time=18.4 ms
64 bytes from lhr25s11-in-f35.1e100.net (216.58.210.35): icmp_seq=31 ttl=54 time=20.8 ms
64 bytes from lhr25s11-in-f35.1e100.net (216.58.210.35): icmp_seq=32 ttl=54 time=18.3 ms
64 bytes from lhr25s11-in-f35.1e100.net (216.58.210.35): icmp_seq=33 ttl=54 time=20.1 ms
^C
--- google.co.uk ping statistics ---
33 packets transmitted, 33 received, 0% packet loss, time 32027ms
rtt min/avg/max/mdev = 18.313/29.806/57.245/15.535 ms
lolowalsh
Message 34 of 295
Horrible today I'm having low speed plus jitter of 500 ms but stable ping at 12.  I spoke to them today and they said they will be sending me their newest hub tomorrow so I will keep this thread updated if the ping spikes stops which I doubt they will.
h3x1e
Expert
Message 35 of 295
Got two for you today, while trying to load Netflix too. Unable to load Netflix properly for a good 10mins, from when I started trying to watch something. Could the two issues be linked? Who knows.
So to give a bit of info on the PingPlotter UI, just before the red line on the bottom graph is when Netflix started to load correctly. Before that it would either load only a white raw HTML page or it could load into a grey screen with the usual circular loading animation on the tab. (did this on every browser)
As you can see from the Ping Logger graph the clump in the middle is from Loading a video, about 2.6MB/s of the connection then after it buffered for a bit around the 440 mark is when it's at a stable bitrate and using about 800KB/s of the possible 3.5MB/s connection throughput.
lolowalsh
Message 36 of 295
New router hasn't made any difference ping spikes all over the place. This is a ping test whislt playing a 480p video on youtube.
I was close to switch to Vodafone but they seem as bad as BT, it seems that I should give up on gaming since all the ISP's in the UK are having the same issue or I should move to another country.
h3x1e
Expert
Message 37 of 295
Not all ISP's have this issue. Vodafone doesn't, Sky doesn't
lolowalsh
Message 38 of 295
I've seen this thread on Vodafone: https://forum.vodafone.co.uk/t5/Internet-speed/100-Proof-of-throttling-twitch-iptv-etc/td-p/2619260/...  and it's worrying.
I don't know about Sky but I need to do some research before switching ISP's, I've giving up on BT and this issue will never be solved it seems.
h3x1e
Expert
Message 39 of 295
Yeah that's the reason I left Vodafone, but it's not the same problem at all. so.
lolowalsh
Message 40 of 295
Which ISP's do you have in mind if you ever consider leaving BT ?
