h3x1e
Expert
Message 151 of 295
Re: Latency Variation (Ping Spikes) during online gaming.
Reason I pointed out that IP in particular was because it was the first BT node I could see, but looking at your route, the spikes actually happen on HOP2 (a HOP i cannot see). If I could see that HOP it might actually help narrow down the issue geographically.
TechTino
Message 152 of 295
Oh I see, thank you for everything anyway. I trust the information you've gained will help out BT a lot with this investigation.
h3x1e
Expert
Message 153 of 295
Hope so.
jonnye71
Message 154 of 295
Hi I’m having the same issue.
what is the problem I need to inform BT to get this fixed??
please help!
jonnye71
Message 155 of 295
What did you ask BT to do to fix this?
shackahn
Message 156 of 295
Here is mine from tonight. Normally my issue is with hop 3 but I cant see 2 or 3 tonight. I have never seen 2. I cant try openzone as my connection is wired.
Streaming sky.
h3x1e
Expert
Message 157 of 295
You need to start doing your own testing and posting screenshots, there's no telling if your issues is the same as everyone elses.
Thank for sharing Shackan
jonnye71
Message 158 of 295
But if mine are, what did you do to fix it?
Thanks for all your help!
h3x1e
Expert
Message 159 of 295
There is no fix.
jonnye71
Message 160 of 295
Ah no that’s so annoying.
What stage are you currently at with BT? Ie what are they looking into at the moment?You seem very knowledgeable in this stuff. I’ve tried changing router and resets. I am getting high ping and latency when gaming whilst Netflix runs.
