jonnye71
Message 181 of 295
Re: Latency Variation (Ping Spikes) during online gaming.
Hey @matthewuncle please let us know what he says as the problem your having is likely the same for us! Thanks
h3x1e
Expert
Message 182 of 295
No Update from my end on this. Everything is the same as previously, nothing changed.
h3x1e
Expert
Message 183 of 295
Just got a latter through saying BT are still trying to fix the fault but also gave me a list of Ombusdmun contact details.
h3x1e
Expert
Message 184 of 295
First update here in a while (even though I've been in close contact with the MOD who's working on my case). The connection had been stable since my last post, as in no drop outs or and noise on the line.
Today though something pretty weird happened, I don't know if this is just the DLM doing funny stuff or if there was human intervention but the net dropped while I was in work and re-synced with the following:
> v s
  ---------------------- ATU-R Info (hw: annex A, f/w: annex A/B/C) -----------
   Running Mode          :      17A       State                : SHOWTIME
   DS Actual Rate        : 42623000 bps   US Actual Rate       :  5432000 bps
   DS Attainable Rate    : 42830904 bps   US Attainable Rate   :  5482938 bps
   DS Path Mode          :        Fast    US Path Mode         :  Fast
   DS Interleave Depth   :        1       US Interleave Depth  :  1
   NE Current Attenuation:       25 dB    Cur SNR Margin       :  2  dB
   DS actual PSD         :     4. 7 dB    US actual PSD        :  4. 7  dB
   NE CRC Count          :      102       FE CRC Count         :  11813
   NE ES Count           :       31       FE  ES Count         :  11179
   Xdsl Reset Times      :        0       Xdsl Link  Times     :  5
   ITU Version[0]        : fe004452       ITU Version[1]       : 41590000
   VDSL Firmware Version : 05-07-09-0F-01-07   [with Vectoring support]
   Power Management Mode : DSL_G997_PMS_L0
   Test Mode             : DISABLE
  -------------------------------- ATU-C Info -------------------------------
   Far Current Attenuation : 37 dB          Far SNR Margin       : 6 dB
   CO ITU Version[0]       : b5004946       CO ITU Version[1]    : 544eb206
   DSLAM CHIPSET VENDOR    : < IFTN >
As you can see from this Interleaving has been switched to Fast, Depth 1 (Down from 200ish)
Also noticed that Impulse Noise Protection has been turned off and interleave delay is now at 0ms down from 8ms, see below for more stats.
  ---------- ATU-R Info (hw: annex A, f/w: annex A/B/C) ------------
                  Near End        Far End    Note
 Trellis      :      1               1
 Bitswap      :      1               0
 ReTxEnable   :      0               0
 VirtualNoise :      0               0
 20BitSupport :      0               0
 LatencyPath  :      0               0
 LOS          :      6               0
 LOF          :      2               0
 LPR          :      0               0
 LOM          :      0               0
 SosSuccess   :      0               0
 NCD          :      0               0
 LCD          :      0               0
 FECS         :   284129          59208 (seconds)
 ES           :     96            11179 (seconds)
 SES          :      0              12 (seconds)
 LOSS         :      0             747 (seconds)
 UAS          :     28            37812 (seconds)
 HECError     :      0               0
 CRC          :    339            11813
 RsCorrection :      0               0
 INP          :      0               0 (symbols)
 InterleaveDelay :   0               0 (1/100 ms)
 NFEC         :    187             255
 RFEC         :     16              16
 LSYMB        :   1496            11424
 INTLVBLOCK   :    187             255
 AELEM        :      0            ----
Could this have been a DLM reset? I'm not sure so someone with more knowledge on seeing DLM resets let me know.
Looking at how fast CRC Errors are rising, I don't expect this session to last a long time.
Also see below for a ping to google while watching a twitch stream, nothing much changed still getting 20ms+ jitter.
h3x1e
Expert
Message 185 of 295
So I had to intervene yesterday as we were getting weird buffering on streams etc (expected with zero noise protection on the line I guess)
I noticed that SNR was at 1dB so I increased it on the modem to 3-4dB and it seems to have stabalised the line with no weird stuttering / buffering happening now. Sync dropped from 42Mbps to 39Mbps but thats expected with an SNR increase and it doesnt bother me as it's still faster than the 32Mbps we got previously.
Even though CRC errors are building at 800 since my last post roughly, we aren't personally seeing and ill effects from it (even though DLM will dissagree and probably intervene soon)
Ping issues still persists btw even though base ping is lower 9ms down from 17ms. Still seeing 20-25ms jitter on a good test, higher on worse.
h3x1e
Expert
Message 186 of 295
As expected DLM didn't like the CRC errors so has now basically reverted back to the normal line settings:
INP = ON (15 symbols)
Interleave Depth = 511
InterleaveDelay = 800 (8ms)
Sync Speed 35Mbps (Better than before)
h3x1e
Expert
Message 187 of 295
Connection drop at 8:30 ish just ebfore Im posting this.
 Nothing seems to have changed connection stats wise although I THINK I got an upload bump to 5.5Mbps from 5.4Mbps not sure though didnt take notice really.
It's raining kinda heavy and windy so did quiet line test also but everything is perfect on that end, will put it down to DLM.
h3x1e
Expert
Message 188 of 295
I don't know if you'll see this Stuart but do you know if there's any work going on at the exchange? Internet has been off for the whole street at least Sky BT everything it seems.
Any info please DM,  we have no internet at all 😛
Tags (1)
Keith_Beddoe
Message 189 of 295
h3x1e
Expert
Message 190 of 295
yeah nothing there about my exchange / area so thats why im asking.
Service Tracker for BT and SKY doesnt show any issues either, but everyone in the immediate area is down.
