g4jnw
Message 1 of 4
Latency issue or not?
Last few weeks i have noticed webpages taking a while to open but its intermittent
I did a speedtest with an online web server and 1186ms no wonder but then tried later and 50ms I tried to do it via BT but as i use a VR900 router as soon as i clicked non bt i can't get any further.
This does not persist however as ive done a ping test just now and get the results below, could it be my router, should i put the BT router back in?
PING www.bbc.net.uk (212.58.244.27): 56 data bytes
64 bytes from 212.58.244.27: icmp_seq=0 ttl=54 time=14.791 ms
64 bytes from 212.58.244.27: icmp_seq=1 ttl=54 time=16.663 ms
64 bytes from 212.58.244.27: icmp_seq=2 ttl=54 time=16.713 ms
64 bytes from 212.58.244.27: icmp_seq=3 ttl=54 time=16.822 ms
64 bytes from 212.58.244.27: icmp_seq=4 ttl=54 time=16.954 ms
64 bytes from 212.58.244.27: icmp_seq=5 ttl=54 time=17.052 ms
64 bytes from 212.58.244.27: icmp_seq=6 ttl=54 time=16.696 ms
64 bytes from 212.58.244.27: icmp_seq=7 ttl=54 time=14.999 ms
64 bytes from 212.58.244.27: icmp_seq=8 ttl=54 time=16.484 ms
64 bytes from 212.58.244.27: icmp_seq=9 ttl=54 time=17.052 ms
3 REPLIES 3
lolowalsh
Message 2 of 4
Re: Latency issue or not?
It's not your router, I've been having simialr issues where my ping spike everyday for the past two months even when the network is idle. I've been trying to fix for the past few weeks and no luck so far, I even esclated to issue to a BT specialist team and got told I'm going to be put on fast path and to wait 10 days, and so far it's been 5 days and still it happens.
I made countless posts here and no one even cared to fix my issue, or at least give me an idea on why my ping pikes to 400+ during the day randomly. I'm waiting for the full 10 days to finish and then switch to another ISP that is not related to BT " Plusnet and EE in the avoid list"
g4jnw
Message 3 of 4
Thanks for that, please post your results, if you get any from BT.
Im in a 18 months contract at the moment and almost 1 year away from renewal so can't move myself without a big cost.
BT has been pretty good up till recently so not sure what changes had been made but tongue in cheek maybe its all been happening since i started getting offers of upgrade.
h3x1e
Expert
Message 4 of 4
Your ping seems fine from what ping results you posted. You'll need to do a long, more in depth ping via Ping Plotter and a graph from PingLogger if you'd want to confirm whether it's the same issue as others are facing.
