Message 1 of 3
Latency/ping issues not resolves by engineer visit
Hi, over the past couple months the home wifi has started getting big latency issues. Every 30-60 seconds the ping will spike from 20ms to 150-300ms which is making it impossible to play any fps or online video game requiring good ping...
I've been in contact with the video game support (league of legends) and have tested the connection, only to find out it is definitely a problem with my end not the video game servers end. I then contacted BT support, was told there was a problem with the line, we would be receiving a BT engineer visit and compensation.
So the BT engineer visits, says the connection is now faster (not the problem i had in the first place, i said the problem was ping and was told natural variance is okay). So why was the engineer even sent out in the first place? The issue wasn't fixed. What even was the problem with the line lol? But either way, the ping spikes continue. And BT support hasn't got a clue what I'm on about and say 'the line is fine'.
2 REPLIES 2
Message 2 of 3
Re: Latency/ping issues not resolves by engineer visit
Are you using wifi or Ethernet?  If a gamer obviously Ethernet is preferable
Message 3 of 3
Wifi. This problem never happened before however, and looking down the forum I see a big thread about almost the same issue. I'm certain this is a problem on BTs end.
