Distinguished Guru
Message 1 of 61
Link BT Home Hub 3a and 3b together
Here's the how to connect a BT Home Hub 3a (primary) to a BT Home Hub 3b (secondary) to extend your wireless range and to create more Ethernet ports!
HH3a (primary) recommendations
Open a browser page and log in to the hub manager 192.168.1.254 or bthomehub.home
Change the default admin password
Click Settings, then Advanced Settings, then Continue to Advanced Settings
Click Wireless
(optional) Change the Wireless network/SSID to one of your choice ie. MyHub
Channel selection - select 1,6,11 or any channel with the least congestion (you'll need to use a wireless sniffer to see which is best)
(if device supports this) Wireless security - select WPA2
(optional) Wireless Key - change to anything you want but note that it:
  • is at least 10 characters long, but no more than 63
  • is a combination of numbers, upper-case letters (or ’CAPITALS’) and lower-case (or ’small’) letters
  • does contain punctuation, but no space.
  • is not a name or a dictionary word
  • does not repeat the same character one after another (e.g. aabbccdd00)
  • is not a commonly used key like ’abcd1234’, ’welcome1’, etc
  • is not the same as information given elsewhere on your Hub (e.g. your Hub Manager’s password, serial number or wireless network name/SSID)
Click apply
Click Home Network, then IP Address
(optional) Change the Lease time to 21 days and click apply
(optional) Click Port Forwarding, then UPnP and select off, click apply
HH3b (secondary)
Factory reset the HH3b by pressing and holding the reset button for about 15 seconds - NOT the restart
Make sure the wireless on the Laptop/PC is OFF
Connect the laptop/PC by Ethernet cable (NOT to the other hub). Open a browser. Ignore the not connected page.
Log in to the hub manager 192.168.1.254 or bthomehub.home
You'll be prompted to change the default admin password
Click Home Network, then IP Addresses. Change the IP Address to one not in use.
eg. 192.168.1.245 (NOT the default .254Smiley Wink) or one of your choice (192.168.1.**), click apply (ignore any warnings)
As the page reloads SWITCH THE HUB OFF, LEAVE THE BROWSER OPEN
Once the hub has rebooted, clear the address in the URL and type 192.168.1.245 or the one you chose
Click Settings, type in your new admin password, then Advanced Settings, then Continue to Advanced Settings
Click Home Network, then IP Addresses, under DHCP Server, Enable select No and click apply
(ignore the warning)
Click Wireless
(optional) Change the Wireless network/SSID to one of your choice ie. MyHubSlave
Channel selection - select a different channel to the one selected on the primary hub - the next least congested channel. If you used channel 1, try 6 or 11.
(the wireless key will be removed)
Wireless Key - use the same key used on the primary
TURN OFF WPS, click apply
(ignore the waring)
Click Port Forwarding, then Firewall and select Disabled, click apply
Click UPnP and select off, click apply
Unplug the Laptop/PC, close the browser
Connect the HH3b to the HH3a using an Ethernet cable or powerline adapters (PLA's), switch the hub3b off and on again and you're done.
You have now extended the wireless range of your home network and increased the amount of Ethernet portsSmiley Happy
Should you find that you don't get a connection, reboot the secondary to re-establish the hand shake to the primary hub.
Unplugging the HH3b will not affect your broadband connection
-+-No longer a forum member-+-
60 REPLIES 60
Message 2 of 61
Re: Link BT Home Hub 3a and 3b together
DS,
Would you mind if I added your instructions to one of my help pages, with credit to you of course Smiley Wink
Keith
Distinguished Guru
Message 3 of 61
Of course you can Keith
I'll reset my 3b shortly and set up again just to double check my method as it was getting a little late/early
Message 4 of 61
a great tip DS thanks
Distinguished Guru
Message 5 of 61
Guys, wow what a headache
Reset and couldn't get it to work.
The above edited post does work, tried 8 times myself and works every time
Distinguished Guru
Message 6 of 61
Just to let any readers know, all devices that I've tested can connect to either hub with no issues:)
Message 7 of 61
Great work DS thanks
Message 8 of 61
Does that mean that your instructions can now be added to my forum help page?
Message 9 of 61
DS,
Reading your last post, it seems that it all works, so I have added it as a link on my main help page.
The direct link is here
Link BT Home Hub 3a and 3b together and extend your wireless to another location.
I just did a cut and paste, so there may be a few extra line spaces that I need to remove, as the html code on Lithium is different to the code that SeaMonkey produces.
I can easily make changes if you want.
Distinguished Guru
Message 10 of 61
Keith
Great, thanks for doing that:). At least you have it in a place that won't get lost with time:|
Nearly at 24 hours uptime and so far so good.
John, thanks;)
