tentotwo
Message 1 of 3
Link BT Home Hub 3a and 3b together
Hi
I'm trying to link together two home hubs (HH3a to HH3b).  I've followed the instructions from another link I got from the forum and connected them from HH3a port1 to HH3b BT infinity using an ethanet wire but all I keep getting is the orange/purple flashing broadband button on my HH3b.
Does anyone have any ideas where I went wrong?
Grahame
2 REPLIES 2
Message 2 of 3
Re: Link BT Home Hub 3a and 3b together
Please see these instructions.
Link BT two home Hub 3s together and extend your wireless to another location.
You do not use the WAN port on the one you are using as an access point.
Ignore the flashing broadband light.
tentotwo
Message 3 of 3
Hi
If i don't use the WAN port then do i use one of the other ports or does this connect wirelessly?
Grahame
