Message 11 of 16
Re: Link two HomeHubs together to extend a home network - slave hub and master hub
Yes, totally different things.
One other point to mention if you use 2 hubs, make sure you set the 2 hubs manually to different wireless channels to prevent interference.
SonicHawk
Message 12 of 16
I hadn't actually left ... I was just on a rather long lunch break.
As they said in Hitch Hiker's Guide - Missing, presumed fed.
Big-Kai
Newbie
Message 13 of 16
Hi there, im a bit stuck with this because, i have been using this system for a couple of years with 3 extra slave hubs connected to my main home hub 5, as a slave hub i have 2 HH3's and 1 HH5, it was working fine with my phone and my ps4 connected either wirelessly or wired, suddenly my s7 edge tells me to sign into the network and drags me to a page that says theres no broadband, my ps4 can't connect via ethernet cable and intermittently cuts off on wireless, i have changed the wireless channels of the slave hubs but to no luck the problem persists, the issue is with all the slave hubs, as the normal main hh5 is still working wired or wireless compleely fine. If you have some sort of help for me i greatly appreciate it as i can't get through a single game without being disconnected. What i find strange is that both my PC (wireless on the 5GHz and 2.4GHz) my laptop (wired) and chromecast all connect fine and function like nothing wrong is happening.
Thanks in advance
Big-Kai
Newbie
Message 14 of 16
Thanks in advance
Big-Kai
Newbie
Message 15 of 16
Thanks in advance
Big-Kai
Newbie
Message 16 of 16
Sorry my post came up 3 times ! because i was registering and made a mistake.
