Message 1 of 5
Linking Smart Hub 2 discs to Fibre 900
Hi Just purchased Fible 900, but cannot link my old Smart Hub 2 discs. I have factory reset but no luck.
Are they compatible or do I need to request a new disc? Thanks
4 REPLIES 4
Message 2 of 5
Re: Linking Smart Hub 2 discs to Fibre 900
The fact that it is Fibre 900 is irrelevant.  If the discs worked with the Smart Hub 2 before, they should work now.
Did they send you a new Smart Hub 3 by any chance?
Message 3 of 5
The broadband service is irrelevant, it is the hub that is relevant. If you haven't changed the hub, nothing should have changed.
Message 4 of 5
Hi yes I was sent smarthub 3
Mmc
Message 5 of 5
Then you need new discs
