Leerod53
Message 1 of 3
Linking up two home hub 5 routers
Hi
As a newbie to the forum I would be grateful if someone could help me with an issue I have
I have a new infinity home hub 5 with my BT subscription which runs well but due to poor reception in other areas of the house
which means I have to put the hub in the centre of the house but this now causes problems as my youview box which has problems with Internet connection to BT Sports etc to overcome this I have purchased another home hub 5 router which I thought once plugging in and connecting to the youview box it would help with the internet strength in this room but I appear to be having problems connecting up both routers. Can anyone help please
many thanks in advance
leerod53
2 REPLIES 2
Message 2 of 3
Re: Linking up two home hub 5 routers
You cannot connect 2 routers to the same phoneline
Message 3 of 3
On both hubs, disable smart setup and split the 2.4Ghz and 5Ghz wireles channels. Make sure all 4 signals have different SSIDs. Change the address of the 'slave' hub to 192.168.1.253 and then connect an Ethernet port on the 'Master' hub  to an Ethernet port on the 'Slave' hub with a Cat5 Ethernet cable.
However, something like this would be a simpler and neater solution. http://connectedhome.bt.com/product/mini-wifi-home-hotspot-500-kit-powerline-adapter/
