TeamForrest3
Message 1 of 6
Log errors, need config help please. (BTHHB5/Orbi)
Hi
Up until yesterday I was using a Netgear Dm200 with my Orbi, but was getting horrendous drop outs.  I was unable to change it to modem only so I dug out my old BTHH5 from under the bed and reinstalled it in 'modem' only mode by disabling wifi banding and DHCP - having read some posts on how to do this, but I think I've gone askew somewhere!! 😞
I've attached logs from the BT HH5 and Orbi RBR50 and screenshots of the IP setups (hopefully).
 BT IP screenshot
Orbi IP screenshot
I know the BTHHB's are not particularly great devices and I am also considering replacing it with another modem if it continues to drop.
 BT Log        Orbi Log
Any help greatly appreciated.   Thank you,  Lauren
Tags (3)
5 REPLIES 5
TeamForrest3
Message 2 of 6
Re: Log errors, need config help please. (BTHHB5/Orbi)
Should have said I'm not on infinity, just standard BB getting about 9MB/1MB
imjolly
Message 3 of 6
I don't think you can get HH5 to run in modem only mode and is probably the problem
there are other posts on the forum abouy hh5 and modem only using search
licquorice
Message 4 of 6
None of the Home Hubs have a modem only mode.  Turning off DHCP doesn't turn a device into a modem, it will still be routing and natting.
TeamForrest3
Message 5 of 6
Can anyone recommend a more suitable modem? I'm currently looking at : Billion 8800NL R2 DrayTek Vigor 130 ..other any other suggestions?
licquorice
Message 6 of 6
If you just want a modem only, your choice is pretty much limited to secondhand Openreach HG612 from Ebay, Draytek130, Netgear DM200 or Zyxel  devices
