I can't seem to find a Logout button anywhere within the Smart Hub 2 Manager. Is this not possible to do? I don't want curious little minds messing with my settings 😁
Solved! Go to Solution.
as soon as you close the hub manager page it automatically logs you out you have to sign back in to make any changes so don't leave admin password lying around
That has not worked....!
Still signed in
You only need to log in for the advanced functions, are you sure you are not just seeing the basic functions.
It doesn't log out immediately after closing web page and then re-opening, there is a timeout function.
nope - just checked, & I'm still singed in, & can access Advanced. 🤔
then factory reset the hub using recessed button on back and try again as it should log out automatically
What may happen if I stayed logged in??
does it only happen with a specific device?
Nothing
That's good - I thought maybe it could be accessed by others, they would have all my data, etc etfc
Thank you
