jackacate
Newbie
Message 1 of 2
Losing connection when changing settings
Every time i click port forward on my settings I lose connection and chrome says
This site can’t be reached
192.168.1.254 refused to connect.
I need to Port foward a port but i havent been able to becuase of this issue. (BT homehub 5)
1 REPLY 1
Moderator
Moderator
Message 2 of 2
Re: Losing connection when changing settings
Hi @jackacate,
Out of interest, what ports are you trying to port forward? Is it for a game, CCTV etc? Has port forwarding worked for you before? Also, have you factory reset the Hub and tried it again?
DanielS
Community ModeratorDannyS
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
