Craig7272
Newbie
Message 1 of 3
Loss of broadband
I live in a flat and the people upstairs have recently bought a treadmill. Now, besides the terrible noise it makes, for some reason the treadmill causes our broadband connection to cut out. I was wondering if anyone could help me understand why this would happen?
2 REPLIES 2
Moderator
Moderator
Message 2 of 3
Re: Loss of broadband
Hi Craig7272,
The treadmill could be causing electrical noise which is interfering with the same frequency that your broadband works on. Check out this link Kitz (REIN) for a more detailed explanation.
Neil
Community ModeratorNeilO
Show your appreciation!
Kudos”Kudos”
Craig7272
Newbie
Message 3 of 3
Thank you for getting back to me. I have already accepted that there isn't much I can do about it, but I appreciate the link. Cheers.
