Benrhayward
Message 1 of 5
Loss of connection when using two devices
Hi guys,
I’ve had BT for about a month now and I’m generally happy with the connection.
One problem that’s really annoying me though is that whenever a 2nd device is connected, one of the devices becomes insanely slow and loses connection.
For example, I’ll be sat watching Netflix in one room on the computer and then my partner will start browsing on her iPhone, Netflix will then stop but the 2nd device (in this case, the iPhone) is fine. The only way to resolve this is to reload the original device (so restart the browser on the computer or restart the app on phone).
Is there anything I can do about this? It seems a little ridiculous that two devices can’t do two fairly low maintenance tasks at the same time? It’s not as if I’m gaming on two devices at the same time or torrenting a large file?
4 REPLIES 4
gg30340
Message 2 of 5
Re: Loss of connection when using two devices
Make sure you turn off "smart setup" on the Homehub.
See link how to do that.
http://bt.custhelp.com/app/answers/detail/a_id/44328/~/what-is-smart-setup-on-the-bt-hub%3F-how-can-...
imjolly
Message 3 of 5
Can you post stats from your hub. If hh6 then advanced settings then technical log information. If hh5 then troubleshooting then helpdesk
Benrhayward
Message 4 of 5
This was the fix, thank you!!
RobbieMac
Moderator
Moderator
Message 5 of 5
Nice one @gg30340  Smiley Happy
