wilkofife
Message 1 of 3
Loss of connectivity
After last nights thunderstorms and power cuts, I have no ethernet connection to the Smart Hub 2.  WiFi is working fine but no ethernet devices recognised.
Have rebooted, changed cables etc etc but am now stuck.
2 REPLIES 2
licquorice
Message 2 of 3
Re: Loss of connectivity
Have you tried a factory reset rather than rebooting?
If that fails, you need to report it to customer services and get a replacement hub.
wilkofife
Message 3 of 3
Thanks for the advice.  Yes, did a reset and no go.  Have hooked up my previous Smart Hub and it works fine, so it is definitely the hub that has been fried.
Customer Services, eh ? BT don't seem to want to talk to anybody these days, but I might as well try.  I am spending enough money with them after all.....
