Guacanoele
Newbie
Message 1 of 2
Low Lan speeds
Hi, I am supposed to get around 50mbps but on average get 30, yet when I use ethernet to a laptop i get around 15??!! my router is in the dining room and I have the same problem with stuff in the living room. I have used powerline and ethernet direct. MY sky Q box, Samsung smart TV and PS4 all get low ethernet speeds. My PS4 as low as 3mbps. How can hardwire be slower than wifi??!!
1 REPLY 1
Message 2 of 2
Re: Low Lan speeds
can you post stats from your router
enter phone number and post results  remember delete number http://dslchecker.bt.com/adsl/adslchecker.welcome
run btspeedtester and when first test completes run diagnostic test and post results  must be done with wired conenction and preferably IE/Edge
